No worries, thank you for coming back to share!
While it’s hard to tell exactly which sensor that is, Cubic is generally a good brand and the size definitely indicates an NDIR sensor. I would say it’s probably quite accurate!
I found technical specs about the sensor
This is pretty standard for an NDIR sensor (which is a good thing here!).
Definitely more than accurate enough to get good insights from.
A great study validating the performance of the Vitalight Mini CO2 Detector - one of the only devices that is accurate but can be found under $30!
