Best Indoor CO2 Map
Hi! Thank you so much for putting this forum together and doing all the work you do. I love reading your reviews and posts.
I was wondering if you would consider reviewing the different CO2 crowd sourcing platforms? At the moment there seem to be a few different ones and I think that people find it tricky to choose which one to contribute to. I know that there is a good amount of interest in people taking part in them.
So far, I know of these ones:
[CO2Trackers] (COVID CO2 tracker), which is one of the first ones
Airspot map, integrated with the Airspot app
There are also these ones:
Raven app, which has since shut down but the data are available on the airspot map
IndoorCO2map, which is quite new but seems to be growing quickly. It has an app that makes submitting the data pretty easy
I’ve tried a couple of them out and would love to hear your thoughts on them!
Thanks so much
Hi @paper,
Thanks for joining the forum and fantastic question! I’ve moved the post to its own topic as I think this is quite an interesting one - I hope you don’t mind!
This is definitely something I can look into! I have been aware of the platforms like Raven App and CO2 Trackers for quite a while, but I’ve never written about them and I think it’s a great idea. My biggest issue with these platforms has always been that they’ve felt a bit fragmented and I never know which one to submit to.
That said, at the moment, there seems to be quite a bit of change and it seems like the AirSpot team is working quite hard to pull a few of these different databases/maps into a single platform. Perhaps @JordanAirSpot could comment on this!
Which is your favourite or preferred map and why?
Yes, AirSpot hosts this crowd-sourced CO2 map here:
AirSpot Map - CO2 Monitoring Data Platform
All data from: Raven CleanAir Map - Thank You has been transferred to the AirSpot map - the Raven CleanAir Map is no longer operating. (There is a filter on our map to find this data)
All data from COVID CO2 tracker has been shared on the AirSpot map (There is a filter to find this data on the AirSpot map)
Heya @Ethan,
Yeah, I’ve had a similar feeling about them all being a bit fragmented.
I added observations to Raven App for quite a while and I was sad to see it shut down. I’m glad that Airspot is preserving it.
I spent the last couple of days trying out Airspot, CO2trackers, and indoorco2map so that I could write about these fairly:
I think that the Airspot map looks really nice right now. Using Mapbox as a mapping platform is a great solution and it makes the interface very friendly to look at. I also love that Airspot is displaying CO2trackers and Raven App data. Its nice to have some integration. I know that the map is very new, so I’m sure it will get some more work in the future, but there are a few things that could be improved. I don’t have an Airspot device, so I can’t test it, but I assume that submitting data from a connected Airspot is pretty easy, however, submitting from non-airspot devices is manual and a bit of work. Also, while the data are open, it would be nice to have a button that makes it easy to download them, so that they could be analyzed for research.
CO2trackers has been around for a long time and I commend the work that went into it, but I don’t think it does anything very well. Visually, its not great, and its clunky in general. It also makes the name of the person who submitted the observation and the serial number of their device public, which I think is a bit dangerous.
Indoorco2map.com is a bit different and focuses on collecting what I’ll call “research grade” data. Observations have to be at least 5 CO2 readings long (ie the sensor has to sample the air five times). On most sensors, that means the recording takes 5 minutes to do (although an Airspot set to a 5 second polling interval could do it in a minute). Its a drag to have to stand around in a shop for 5 minutes, but it does mean that the data is much more reliable and less noisy than Airspot and CO2trackers which only report a single CO2 reading (correct me if I’m wrong). Another benefit is that you can see how different parts of buildings have different levels of CO2 (see attached image as an example) and some of the longer recordings show how ventilation systems turning on and off affect the CO2 levels.
To do an indoorco2map recording, you have to be physically located in the building you are measuring (you can’t manually submit them later), again this is a bit of a drag, but it does mean that its much harder to fraudulently submit recordings. The app does make doing the recordings very easy and once you’ve tried it a couple of times, it becomes second nature to start one when you go into a shop and then submit as you leave.
Indoorco2map doesn’t collect any user data (except location and CO2 readings), there isn’t even a sign in feature. I like this a lot because it means submissions can’t be traced back to me.
Lastly, indoorco2map has a button that allows downloading the data very easy. There’s also an R package for analyzing it.
So if I had to pick my favourite, I’d say that Airspot is visually the best one at the moment, but indoorco2map wins in data reliability and ease of data collection.
But ultimately, I don’t think this has to be a competition, as long as people are contributing to a global dataset of CO2 recordings, I’m happy. And having platforms like the Airspot map, which integrate all of them, takes away the need to choose.
@JordanAirSpot are you planning on integrating the indoorco2map data too?
Hi @paper,
Thanks for your insights.
Yes, we are talking to CO2trackers, but note there is a discrepancy as you have highlighted in the way data is presented, so this will require us working through this before we can add to the map.
Yes, if you have an AirSpot it will pull data including current CO2 reading from the device, making submission quicker.
Do you have any ideas on how we could streamline data submission from non AirSpot devices?
We are continually working on the map to make it better!
I can raise the download data button option with the team here.
Any other suggestions or feedback, we would love to hear it!
Cheers,
Jordan @ AirSpot
I hear there is going to be a talk from the creator of the indoorco2map about the project tomorrow. Might be of interest to you @JordanAirSpot @Ethan
Thank you! I missed it, but will watch the recording
A post was split to a new topic: Best Classroom CO2 Monitor
I got round to watching it this evening. Very interesting.
I was pretty intrigued when Aurel talked about how shoe stores often have good ventilation because they don’t want the store to smell bad.
And the differences between Costco and Home Depot as well as Aldi/Lidl vs other supermarkets were pretty cool
