Outdoor Air Quality Monitors
While my website initially focused mostly on outdoor air quality, that changed over time as the pandemic hit. Despite my interest in outdoor air pollution ([that is the reason I started my blog] (BreatheSafeAir • About Me)!), I recognised that there was a much more pressing matter at hand: indoor air pollution.
While the pandemic is far from over, I now have more time to focus on outdoor air quality monitors again. Recently, I was finally able to review my first dedicated outdoor air quality monitor - the AirGradient Open Air. I was impressed with the monitor and loved how much insight it gave me into the concentrations and make-up of outdoor air. Since that review, I’ve wondered how other outdoor air quality monitors perform.
I have the Purple Air Zen on the way for testing. Still, in the meantime, I wanted to start compiling a list of outdoor air quality monitors that are in a relatively similar price range (within reach for most consumers) and have a similar feature set. While I’m sure I’ve missed many, as this list is just off the top of my head, here are the monitors I’ve looked at so far.
Air Quality Monitor Pollutants Measured Sensors Cost
AirGradient Open Air PM (PM1.0, PM2.5, PM10) & CO2 (on newer models) PMS5003T, S8 $125 (DIY), $190 (Assembled)
PurpleAir Classic PM (PM1.0, PM2.5, PM10) 2x PMS5003 $229
PurpleAir Flex PM (PM1.0, PM2.5, PM10), Pressure, Temperature, Humidity & Gas 2x PMS6003, BME688 $289
PurpleAir Zen PM (PM1.0, PM2.5, PM10), Pressure, Temperature, Humidity & Gas 2x PMS6003, BME688 $299
AirVisual Outdoor PM (PM1.0, PM2.5, PM10), temperature, humidity, air pressure, & CO2 (optional) (unsure. Likely IQAir co-developed sensors as with the AirVisual Pro) €319.00
As I mentioned, this list of outdoor air quality monitors is far from complete, and I’m sure I’ve missed many. However, both for my own sake and anybody considering an outdoor air quality monitor, I will update this in the future as more monitors come across my radar!
I forgot to add the Model X from CO2 Click to the list. The Model X is another great, affordable option.
For Canadian $209, you can get a monitor with a Sensirion SPS30 and Bosch BME280. I haven’t yet tried this monitor either, but it’s small form factor and inconspicuous look could make it ideal for some uses.
I am currently testing the Purple Air Zen (Purple Air’s newest outdoor air quality monitor). So far, I am still in the early phases of testing, so I won’t go into details yet, but I do have a few first thoughts.
For anyone wondering, the Zen and the Flex are quite similar, but the Zen looks to be positioned as the successor to the Flex as it’s both slightly more expensive and has a few extra features. However, both monitors have the same sensors (two Plantower PMS6003 sensors and a Bosch BME688).
Interestingly, however, the Zen seems to be an incredibly incremental update, and I have to wonder why the choice to release it and sell it alongside the Flex was made. As per this post on PurpleAir’s forum, the only two major differences are the LED ring and double-tap functionality (to change LED brightness) on the Zen.
Based on this, I have to assume the Flex is meant more for applications where people don’t want the monitor to be noticed as it’s very inconspicuous. On the other hand, the Zen is made to stand out.
I will be sharing more thoughts soon!
Over the past few weeks, I’ve had a chance to try a few more outdoor air quality monitors, including the PurpleAir Zen, CO2 Click Model X and AirBeam 3. After using AirGradient Open Airs as outdoor monitors almost exclusively for many months, I have quite a few thoughts to share. While I have full reviews upcoming, I want to discuss the CO2 Click Model X in particular, as it’s impressed me so far.
This CAD 209 monitor comes in at roughly half the price of the PurpleAir monitors, and it’s even cheaper than the AirBeam and AirGradient monitors (unless you get the DIY kit, which is slightly cheaper). While it only has a single sensor, it is a more expensive Sensirion SPS30 (as opposed to the Plantower sensors used in all other monitors mentioned here). I’ll discuss the accuracy in more detail soon, though, as that has left me the most impressed about this device.
You are trading some other features, such as local data storage (on the PurpleAir monitors), cellular connectivity (AirBeam 3), and the ability to monitor CO2 or NOx (AirGradient Open Air), but there are also a few key benefits to the Model X - in particular, the pricing and the completely free dashboard with up to four years of data.
While each monitor certainly has advantages, and I would argue that the Model X has the least developed platform (due to it being newer and managed by a much smaller team), I have been very impressed with the device’s performance, so let’s discuss that!
All the other monitors I listed use Plantower sensors, but they use different models. AirGradient uses the PMS5003, PurpleAir the PMS6003, and AirBeam the PMS7003. However, despite the naming scheme, each of these sensors has very similar performance, with the key differences being in size and connection options. On the other hand, the Model X uses the Sensirion SPS30.
Which of these sensors is more accurate is still up in the air, as some studies point to the SPS30 performing better while others have found better performance with Plantower sensors. Either way, I tend to look at the sensors as roughly comparable - at least for PM2.5.
https://www.scirp.org/journal/paperinformation?paperid=107924
I wanted to make some comparisons, so I decided to graph the PM2.5 concentrations recorded by the Model X and a couple of PurpleAir monitors over the same period. At first, I found that the sensors recorded vastly different values, but after doing some research, I found it’s common knowledge that the PurpleAir monitors (and likely most Plantower-based devices) significantly overreport PM concentrations. For this reason, the EPA developed a correction formula to bring their readings more in line with federal reference equipment (at least for smoke and urban pollution).
Before the EPA correction. Please note that Model G is mislabeled (it should be Model X)
After EPA correction. Also, sorry for the imperfect ChatGPT graphs…
After exporting data that had been EPA-corrected, I was surprised to find that the Model X with the SPS30 and the PurpleAir devices showed very similar readings. While I’m unsure what corrections Sensirion applies, I was impressed at these results and, while I lack access to reference equipment, I would take this to mean the Model X accuracy is good.
A full review is coming up soon, but I was impressed to see the similarities in readings, and I think the Model X might be another good (lower cost) outdoor air quality monitor option!
PurpleAir Flex and Zen review:
These are probably the most popular outdoor air quality monitors on the market, and after spending some time with them (and continuing to use them daily), I think they’re a great option - potentially the best for many users.
Another option that I thought was purely a portable air quality monitor, but that turns out to have some great features that can be used as a static outdoor air quality monitor, is the AirBeam 3.
This ghostly monitor is intended firstly as a portable air quality monitor, but due to it having a built-in GPS, SD card for local storage, and SIM connectivity, it becomes a good option as an outdoor monitor, too. On top of that, it’s weather sealed, and comes with a karabiner so it can be hung anywhere. When needed, you can opt to use it as a portable monitor instead.
I am currently working on a full review for this monitor and will share it when complete.
I’ve finally had the chance to test the AirVisual Outdoor and I am looking forward to writing a full review on this device soon! I’m a big fan of being able to see the outdoor concentration on the AirVisual Pro (indoor monitor) and think this is a very cool implementation for comprehensive air quality monitoring.
Hi, I’ve been running an AirVisual outdoor for perhaps a year and a half now. I’ve found it really simple to run. The power over the WLAN feature is good saving on having to use wireless that does tend to be somewhat less reliable.
Only had a few occasions where it has stopped reporting. Most because of the broadband failing or the router switching off.
Needed to clear the sensor after a year of running - the app gave instructions and once done it has carried on faultlessly.
I think that IQair use their own proprietary sensor that does produce PM10 data. To be honest I’m sceptical of it’s PM10 results - always seem to be an extrapolation of PM 2.5 and as such I don’t use the PM10 data.
The other parameters measured are less useful to me. I assume that the humidity sensor is there to try to reduce the affect of water vapour on the results? Unfortunately IQair offer less information regarding corrections they apply that say PurpleAir who give the options to use no or varied correction factors.
The App is a bonus, although you’ll always need to download the raw data or in order to work on it (pollution roses etc).
My only gripe is the PM10. I’d be keen to have a way of getting accurate estimates of PM10 that aren’t based upon the measured PM2.5 indicative data.
PurpleAir have recently ‘retired’ PM10 from their data views reflecting well known inaccuracies and I suspect it isn’t very different with regard to IQair’s. Would be very helpful to me if IQair introduced a PM10 orientated sensor add in!!
Cheers
Hi @DJSWALES,
Thanks for joining the forum and sharing your experiences with the AirVisual Outdoor - it’s great to hear from someone who’s been using it for a long time already!
This is quite cool - did the app also warn you that the sensor needed cleaning, or was this something you figured out yourself?
Yes, I think (as with nearly every low-cost device), the PM10 readings shouldn’t be trusted. However, it looks to perform decently to quite well (depending on the test in question) for PM2.5.
I agree and think this would be very cool. I would also love to see the sensors expanded generally. Even if they’re a bit pricey, it would be great to see other gas sensors (besides CO2) available.
My favourite feature of the AirVisual Outdoors is the ability to show the PM concentration (from the outdoor monitor) on the indoor AirVisual Pro if you have it.
Hi, sorry for late reply. The App warned me when the sensor needed clearing. If I remember correctly the PM level had increased then I had a notification that the data wasn’t being uploaded as I guess they suspected anomalous readings. The App advised cleaning the sensors with a keyboard dust spray can. Did that and the readings went very high as I suspect there was condensation from the pressurised air spray. Shortly after it settled down and started uploading again.
I haven’t the indoor monitor so rely on the App. The App could be better if it allowed more graphing options, most of the time I download the data then work on it in MS excel.
Live about a km from a stone processing plant so wanted to see whether activities there were an influence. Have since learnt that I’d need a monitor capable of measuring PM10 properly. As for the PM2.5 there are clear trends depending on wind direction. North westerly winds tend to carry far less PM 2.5 that makes sense as they’re coming from a more rural area. South easterly carry a lot more probably due to Cardiff/Newport and further afield.
More locally it’s wood burners that send readings up and the 5th Nov fireworks. During spring summer get a lot of ‘wildfires’ further North and West up the valleys and if downwind certainly know about it with elevated readings from fires as far as the Neath Valley.
No problem at all, I appreciate you getting back to me!
It’s great that the sensor warns you when it needs cleaning. I wish more monitors had such features (especially those with dual PM sensors).
I am excited to test the device further and to see how it performs compared to other outdoor monitors!
As a small update to this topic, I recently compared both the PurpleAir Zen and AirVisual Outdoors to a reference instrument (Palas Fidas 200s) over one weekend in Thailand and I was very impressed by the results! You can read my full article on the AirGradient website:
In short, both monitors performed very well and I think they are both great choices if you’re looking for an outdoor monitor. It was also my first time trying AirVisual Outdoors, and I think I might need to get one myself! Anyway, here are the results:
