Please help improve air quality
Hi, I would like to improve my air quality. I live in an appartment, the appartment is a second floor. My bedroom has very poor ventilation, since my window faces a laundry, where people have their washing machines, AC units, dusty tubes all over.. good stuff.
My bathroom has no window, and the ventilation duct is filled with dust. I don’t know what do with that, since if I put the vacuum cleaner here, aren’t I just pulling in all the dust, potential viruses and stuff stored there? Plus it would only remove it on my end, the rest of the duct on the building is filled with dust anyway, since I doubt people clean it. The ventilation grill is glued there, you cannot remove it. Shouldn’t a company hired by the community do a maintainance and clean the entire thing? They have never done that.
The bathroom also builds up mold, probably after showering due the humidity, it has some mold buildup here and there.
I have been trying to find a good air purifier. I bought a Levoit Core 300, and I have a Temtop LKC 1000S
This is me moving from my livingroom (which has a balcony to the outside) to my bedrom with the purifier at speed 1 (picture 1)
It is successful in lowering pm2.5, but look at HCHO (picture 2)
It’s higher in my bedroom. The Temptop does not have a chart for VOC but it’s also higher (picture 3)
In my livingroom (picture 4)
(I had to put all pics together in one pic because it wouldn’t let me post more than 1 attachment):
While it seems to work for lowering pm2.5, it does nothing for HCHO and VOC. This is quite disappointing considering the marketing these guys have. How are they allowed to sell them claiming it lowers it? Levoit simply told me to buy the smoke filter, but from what I’ve researched, the activated carbon surface is too small on commercial grade filters to lower any relevant amount of these compounds. So basically, I need an alternative to lower them. The question is how?
Im also not sure if the meter is even accurate. I wanted to buy an aditional meter and test. I was thinking of the Airthings 2960 View Plus, it tests radon, PM 2,5, CO2, COV, humidty and temp. Im also interestd in the radon, since I live in Spain near the beach, and in some places there is radon. But im not sure if this is also accurate or not, an some people complained on the app being a bit lame. Can I use this device and collect data while I turn all wireless off at night? Could I just download the data on the computer and check months worth of charts? Since I may need to run it for 90 days to test for radon properly. Other alternatives mentioned I’ve read are the Aranet4 Pro, which measures CO2 (carbon dioxide), temperature, relative humidity, atmospheric pressure, so it will be lacking pm2.5, VOCs, and radon. I would need to buy the Aranet Radon one separately, so I wonder if this means the Airthings one will not be accurate.
While I live a building in the second floor, this elevation may lower radon, but I want to double test. This is an old building, I think the components are decaying and leaving particles in the air. My chest feels irritated sometimes, I don’t smoke. I would like to be able to find what’s up with the air and fix it. Please let me know.
Thanks for joining @waki and great question! This sounds like a tough situation to be in, but I’m sure there are some ways you can improve your air quality.
Yes, I agree. I don’t think it is a responsibility that should fall on you and I also don’t think it would make that much of a difference since other parts of the vent are likely blocked/dirty too. I guess you could try adding a filter at your end, but since it’s quite dusty anyway I’m not sure how great the airflow would be.
Do you normally run the ventilation system (I’m assuming it’s an extraction system?) or not since it’s dusty? One thing that I used to do in the first apartment I lived in in Korea (similar situation with the bathroom having no windows or an extraction fan) was to keep the bathroom door open at most times so it never got too damp.
Overall, your PM2.5 levels look quite good (but lower is always better!). This brings us to VOCs… which are very tough. In short, I wouldn’t pay too much attention to VOC readings from low-cost monitors unless there is a significant/regular trend. I’ve had quite a few discussions on this topic here already, and I would recommend reading these two posts for more details:
If you’re worried about VOCs and HCHO in particular, I wouldn’t look at air quality monitors, but rather getting a professional test (I discussed that a bit in the thread link above) as they are far more accurate and will likely put your mind at ease. They also tend to be affordable in most countries.
When it comes to radon, then yes, I think a monitor could be a good choice! Since you already have the Temtop monitor, would you be primarily looking for a radon monitor, or would you like an all-in-one device (like the Airthings View Plus)?
There is no ventilation system like I said it’s just a grill in there. If I leave the door opened, the problem is you would have a stream of contaminated air go into the rest of the appartment. Bathroom could have e.coli everytime you flush the toilet pushed into the air, you could have stuff comming from the dusty grill, plus mold spores that you have not spotted etc. I leave the door opened after a shower when it’s wet, but when it dries I close it. I use a product to clean the walls to stop any mold. But like I said I don’t like the air quality in a bathroom with no windows or proper ventilation so I prefer to have the bathroom door closed. I wanted to solve this by installing an extractor with a filter, but like I said if the ventilation duct is blocked by dust, then I don’t know what to do.
I will need to find more information about who is a trusted source for this in Spain. What do profesionals use that is so expensive that it would be worth it not buying the device yourself?
Well I wanted one that could do everything like the View Plus but I’ve read it’s very inaccurate, people bought like 3 units, compared them, they gave different readings, so it looks like they have some random number generator and it’s all a waste of money.
So you think the Temptop I have is accurate for at least pm2.5? For radon and the rest, I don’t know what to buy at this point, if you look around for reviews, nothing seems accurate.
Ah, I see. Thank you for the clarification.
I think this is the best you can do - as you’ve mentioned, it’s better to keep the door closed once the bathroom dries, but at least until it does, opening the door can help prevent mould from building up.
I still think this might be the best bet, and it could be worth looking into if the ventilation system is usable. With a filter, you’d at least have clean air circulating through the bathroom.
It depends on the exact test in question, but air quality monitors are very limited when it comes to monitoring VOCs (please check the above-mentioned link for further information). Not only do most of them use a relative scale, but there is no way to identify which VOCs specifically are present. Professional tests can identify which VOCs are in the air and provide an absolute measurement of these. They don’t use monitors (some do, but not the tests I’m thinking of), but rather collect a sample of your air over a few weeks and then send it back to a lab for analysis. I generally don’t recommend these kinds of tests unless you have a specific worry, but I think in this case it could be useful.
For PM2.5 I think it’s okay. For radon, I generally check accuracy reports from this organisation.
Hi Waki,
I can really relate to your situation. A couple of years ago, I lived in a second-floor apartment with poor ventilation and a window facing an internal courtyard crowded with AC units and vents almost identical to what you’re dealing with. I started exploring air quality devices for homes and quickly realised that most entry-level purifiers aren’t very effective against VOCs and formaldehyde. I first used a basic home indoor air quality monitor for tracking PM2.5, CO2, and humidity, but the results felt incomplete.
Eventually, I upgraded to a dual-monitor setup using the Aranet4 and a device from PrimoAire, which offered clearer real-time data across various pollutants. It was eye-opening to see how cooking and even cleaning products affected indoor air levels.
To deal with the bathroom issue, I installed a portable extractor fan with a built-in filter and added a small dehumidifier. This helped control moisture and reduced mold buildup. I also placed a HEPA purifier in the hallway to limit the spread of airborne particles from the bathroom. If you’re considering the Airthings View Plus, I think it’s a good all-in-one solution for tracking radon, VOCs, and CO2 though I recommend validating its data with a second device just for peace of mind. You’re already ahead by being so proactive, a few upgrades and consistent monitoring will likely make a noticeable difference. Let me know if you’d like help choosing specific gear.
