Review Requests
Hi, everyone!
I just wanted to pin a thread where you can request reviews if you’re interested in seeing my thoughts on a mask, respirator, air quality monitor, or air purifier on BreatheSafeAir.
If you’d like to see something specific covered, please comment below! Thank you.
Hello! I found about Screek SCO2-1 sensor based on ESPHome and SCD40 with Home Assistant support which is also how I found about their DIY devices because it seems kinda popular on reddit. I was curious if you had any experience with it considering that it’s cheap and comes with good support so it might end up as a good entry level co2 monitor.
@Ethan First: great website. A lot of good work you do with this website!
The website with the ‘review and overview of sensor stations for mainly indoor air quality’ needs more visitors.
In Holland there are quite a lot of citizen initiatives busy with DIY air quality measurement stations. The national health organisation RIVM is trying to bundle the effords in ‘Samen Meten’ (together we measure) initiative. The work has a relation with some EU sponsored projects. But basically the hard work is mainly done on personal budgets. Yes there is a relation with Sensors.Community initiative in Germany on exchange of measurements.
In order to improve the quality of the measurement stations, stations mainly born from DIY stations, a local inititiative (BWLvC.eu, website is in Dutch) started with the help of other inititiative to work on a ‘warenonderzoek’ (consumer overview) of outdoor targeted airquality measurment stations for PM emissions. See ‘low-cost fijnstof meetstations, een warenonderzoek’ for more details of the draft document. The document is in Dutch.
For more work in progress of data analitics as what is happening in the agricultural environment where I live in, see e.g. ‘Three years of measurments, what now?’. The document is also about what did we learn from building the stations, data acquisition, data analytics and visualisation of data. The document is in Dutch: try a translation service.
Hi @gyuvin, this is a cool project that I hadn’t heard about! I haven’t had any experience with the device (yet), but as it’s based on an SCD40 I imagine it would perform quite well - provided the auto calibration cycle is either disabled or managed well. I will see if I can learn some more about the device!
Hi @teus, thank you for your kind words and welcome to the forum!
I am aware of the Sensors.Community platform, but I wasn’t aware that the platform was also being used by governments and organisations such as RIVM - it’s great to see actual citizen science used to help create policies. I might have to see if I can build one of the sensors myself to see what it’s all about!
I will translate the document/website and have a look, as this sounds very interesting! Thank you for brining my attention to what is happening around air quality in Holland.
@Ethan – appreciate all the info you have posted. We have a need to test absolute VOC levels (probably eventually with the ability to distinguish underlying cause). Is there a monitor that we can buy (theoretically price is not an issue) that would provide that (and if so, which would you recommend?)? Or should we have professionally tested?? Thanks. Curt
Hi @ccdashort, thanks for joining!
I assume you have already read through this thread (or are at least aware of the issues with VOC sensors? If not, I would highly recommend reading at least the first few posts first:
If you want to test absolute VOC levels (and especially if you want to be able to distinguish exactly what VOCs are contributing to the overall concentration), I would recommend a professional test.
After you get a professional test, it could be worth adding an air quality monitor to your home so you can keep an eye on concentrations. However, based on what you’ve said, I would definitely recommend starting with a professional test!
Thanks for all the important and interesting work reviewing masks. I have done several stone wall building projects that require a protection mask for stone dust. I have worn a 3M half faced mask for these projects but would love to find something more comfortable and perhaps cooler as well. Have you ever tested the Forced Air mask with face shield? Regards, Michael
Hi @Michael,
Thanks for joining! I appreciate your kind words.
Which 3M half-face respirator did you use? If I know what you’re using as a point of comparison, it will be easier to make some recommendations.
I have not tried this one yet! Do you have a link?
A post was split to a new topic: AirValent TravelLite vs AirSpot
Hi, requesting a review for the SwitchBot CO2 Monitor. It has an NDIR sensor and is 70$, have only seen a few posts about it online though.
Relevant links:
https://www.reddit.com/r/AirQuality/comments/1kx4azn/co2_trended_for_airgradient_one_vs_switchbot/
Hi @windlord55,
Thank you for the suggestion! I hadn’t come across this monitor before, but it definitely sounds like it would be worthwhile to review! I will see if I can purchase one and get it in for testing.
3 posts were split to a new topic: Thoughts on Prana Air Air Quality Monitors
2 posts were split to a new topic: Best Indoor CO2 Map
3 posts were split to a new topic: Thoughts on the IKEA Alpstuga Air Quality Monitor
Hi!
First, you’re doing an amazing work. Second. Want to suggest netatmo Air Quality Measurement Device | Netatmo as a very popular smart home air quality monitor
Hi @Alpi,
Thank you for joining and for the kind words!
I just replied to your email and I think this is a great suggestion. I will see if I can get my hands on one :slight_smile:
Not a review request but read your review on the Corentium Home 2. If you are in the USA, would you chose the Corentium 2 or Ecoqube? If the different sensor less reliable long term in the airthings?
Hi @Bgildenstern,
Personally, I would still pick the Corentium Home 2 because I think it generally provides a very good user experience, relies on batteries, and has slightly better rated accuracy (after a couple of months of use). Both have been tested by C-NRPP, too: Consumer-Grade Electronic Radon Monitors – CNRPP
As far as I am aware, there are no tests that show long-term performance of the two devices and they will both drift over time and eventually need to be replaced.
